Xtype 2002 window help
Hi i have a completely dead driver window that gets no response. Both right side windows work perfect, back left is mostly working sometimes it wont go up easily but i think its something with the track and will deal with later. Looking to first replace the fuses for them and wondering which fuse number they are as i dont have a manual for the car. Did some research on here and saw both 50 and 11 nots sure if those are correct and looking for some help. Would like to try this first and hopefully wont have to do the disconnecting batter method. Thank you
Most likely the regulator. This can be a minor as chuffed wiring or major the unit died. It necessitates door card removal and inspection. Rarely is this posted by a forum guru, Thermo =
For those with issues on the right windows, odds are, you problem lies in the driver's door switches. If they become loose, the switch does function like it should and results in the window not getting properly configured. If you pull off the driver's door panel and then get the switch in the proper position, all will work better. Kinda like you can get it to work a bit better by lifting and pulling the switch sideways towards the outside (as I recall) as you lift it to make it go up with the 1 touch feature.
qwiketz
01-30-2010 09:14 AM
