Xtype 2003 sunroof problem
Guest
Posts: n/a
Hi Everyone! Hope someone can help me. I have a 2003 Xtype and the sunroof this morning started a problem. I had it open on tilt. I pressed the switch to close and it did nothing. I pressed the switch up and it started to close but I had to hold the switch in. As I held it in, it then went through to open, close, tilt open, tilt close etc... If I release the switch, it stops. It wont work unless you hold switch and it wont get to a closed position unless I watch and see if it closed and then I release switch.
Anyone heard of this before ? Can I buy a new switch if that is what it is or is there something I can do ? I heard about resetting but dont know how to do that if that is what it is.
Any HELP greatly appreciated !
Aldo
Aldo
Aldo
Aldo
1. Sun Roof closed.
2. Push forward to tilt Sun Roof.
3.Press & hold button in tilt position for 20 sec.
4. Release button & immediately press & hold again for 20 sec.
5. Keep holding button as Sun Roof will 1st tilt on 1st push then on 2nd push will close, tilt, close, slide open, slide closed
6. Sun Roof is now re-programed.
OkieTim
09-08-2015 04:48 PM
