Xtype height adjustment motor for driver seat
Not too cheap, either.
http://m.ebay.com/itm/JAGUAR-x-type-seater-gear-ELECTRIC-SEAT-MOTOR-repair-kit-2001-2009-easy-way-/191783513839?nav=SEARCH
i have a 2004 X-Type Sportwagon. As is commo, the gear on the power seat up-and-down function has stripped. I've been able to obtain another entire power seat rack with motors. However, the gear for the power seat of my down function on the replacement assembly is also bad. So here's my question: can a gear be taken from the back-and-forth or the seat recline assemblies and used for the up-and-down function? Or are these different gears?
I bought a set of metal seat gears to replace the plastic ones, ordered them from England through eBay, cost less than $40 for everything needed, the instructions were a little funky, but with minor fabrication( grinding off the old plastic gears to allow drilling a hole for the set shaft for the metal gear) it was a cakewalk, beats buying the complete setup(motor)at jag. They don't sell the gear, as it is pressed onto the shaft, you would have to buy the complete motor Assy
from dealer
maxie
from dealer
maxie
