Xtype mtm linkage cable
Has anyone ran into an issues with the gear linkage cable ? I've noticed an issue when I would be driving when I put the car into gear. It would pop out of it right when your releasing the clutch. Anyways it would happen on and off to where now I lost all gears. So it turns out the cable that connects on top of the transmission which I believe is gear linkage cable or the shifter cable. The wire has rotten away. You can still start the car with the clutch in. But don't have any gears. My question is have anyone one of you guys ran into the same issue or have replaced this cable. Any help would be great! Thanks
