Squeak and wheel bearing question
I own a 1995 vanden plas with about 74,000 miles on it. There is a squeak coming from the right rear wheel. when i hit the brakes it makes no difference until i am stopped then it goes away and starts back up when i start to go again. I was thinking this may (or may not) be related to the wheel bearings. I bought the car from my grandma who had the car serviced regularly and kept all the service records. When i went through the service records i noticed that there was nothing about the wheel bearings being replaced or serviced besides an adjustment on the right front one back in 2003. I kind of find this hard to believe considering how this car was babied but is there a way to check and see? also if i do have to replace them can anyone give recommendations as to a brand and how hard is it to replace them (I’m pretty new to cars.). Any advice is appreciated and any other thoughts on what this squeak could be from.
Thanks,
Chase
Thanks,
Chase
Thanks,
Chase
Thanks,
Chase
That may not be your problem, but it's one possibility.
Cheers,
squeak
I have the same exact problem ATM..The Squeak noise won't be there until I pick up some speed then it will be there until I do a full stop. Once I take off again its there. My dad was saying I need new Rotors and brakes..would that fix it? I know if you need new brakes that your car will squeak while applying brakes but my Squeak noise is constant during driving & braking.
Hey guys. My '96 X300 has not had any squeaks since I've owned it and has none now. 180 plus K and also has no rattles, squeaks, clunks, or rattles (knock on wood) so I'm not complaining. I have come to believe this may be the best car I have ever owned including my Vette.
Cheers,
The X300 still has 4 grease nipples, on the half shaft universal joints, complete with pretty little rubber caps. NO ONE ever greases them, including the dealers in those days (I worked for one).
My X300 had the squeaks when I picked it up, and having heard this on the Beast (XJ-S) I quickly squirted some grease in each nipple prior to the 2000km trip home, and not a squeak was heard.
Bet that is your noise, simple 5 minute fix while the kettle boils.
BEST Jaguar I have ever owned, and there have have been many before it.
Worth a check.
Cheers,
innzane
09-02-2015 10:08 AM
