2.0 Diesel Engine known issues?
Hello again!
I just bought a 2.0 Diesel XE with 180ps and 40.000km on it from 2016.
Now i heard something about broken down engines in some german forums but i wasnt able to figure out the reason and if there is any kind of indicator for it. I really want the engine to have a long and awesome life so im a little bit worried about it.
Is this a known problem and is there anything i can do to avoid this?
Best regards and thank you in advance!
Received 2,636 Likes
Hello again!
Even a modern Mercedes would be pushed to do that sort of mileage.
Petrol Ingenium engines are quite recent, all the first engines were diesels, so Jaguar fitted a Ford petrol engine. All early experience of Ingeniums was therefore with the diesel version. As far as I know, there was a problem with early camchain wear. As the cam drive is at the rear of the engine, replacing the camchain, and maybe the tensioner too, is far more involved as the engine has to be removed first. As you will appreciate, this ups the labour content of the job. However, your car is a 2016, so shouldn't be affected.
zyahya
01-29-2021 09:56 PM
