Chip guards for 2018 XE
I have a 2018 XE with the same problem riddled with stone chips at only 900 miles, and I am told that Jaguar will not fix it as road damage is not their responsibility. This seems to be a common problem although the dealer has told me that they have never seen stone chip damage before. Only drive on black top roads and cannot understand how the car got so many stone chips, and it looks terrible. I have the 18 inch wheels and I am wondering if this is the cause. I would gladly have purchased mudflaps or a guard had I known about the possibility of chips
I've moved your question from XK/XKR(X150) to XE (X760) forum. Members here with the same model will be able to help.
The chip problem on the flare is common on every XE, with or without flaps. This is one of the aerodynamic flares of the car designed to cut wind resistance, so as a forward facing piece very close to the pavement it will suffer abuse. I have flaps on mine and still have the problem.
You can get your own clear vinyl wrap and custom cut your own clear protectors to fit, I know of no pre-cut pieces as the XE is still somewhat rare compared to the beemers and other largely mass produced cars on the road.
FRANCOT1 (04-20-2018)
Yes very common issue that I had myself. I only drive on highways as well and after 2000 miles I was already noticing it was starting to look bad. I had the chip guard film put on. That works incredibly well. I am sure I could have bought it and done it myself, but the place I had it put on at also fixes all the small road rash and chips. They touched up the larger ones with the touchup paint I purchased and then they have some sort of chemical wash or something that fills in the road rash stuff then lay the film over that. They did a great job. I can't tell the film is even on there unless I am really looking. You can purchase the precut stone guard protection pieces off ebay for pretty cheap. They have ones that just cover that back flared out part or ones that guard the entire lower rocker wheel to wheel.
Not sure about Ebay, but here are some custom films for the XE:
https://www.aliath.co.uk/collections...r-clear-shield
and
https://www.aliath.co.uk/collections...int-protection
and
FRANCOT1 (04-23-2018)
I paid $180 to have it put on. This covers the rocker wheel to wheel and he also went up all the way up the edge of the door as well. It did not include behind the rear wheel.
FS[UnitedKingdom]: FOR SALE X350 XJ6 Sovereign 3 Litre V6
d.niven
12-03-2017 10:49 AM
