Coolant for XE
The original coolant specification was:
50% mixture of water and antifreeze specification WSS M97B44 (coloured orange) Extended Life Coolant.
This has been superseded for all vehicles by:
Mixture of 50% water and 50% antifreeze meeting Jaguar Land Rover specification STJLR.651.5003.
Specification is not to be confused with brand. Several brands meet or exceed both specifications.
Thanks for the replies.
The spec given by GGG is indeed a Ford spec and is the right orange coolant for my 2018 35t
I found that several brands claimed to be suitable, but they all seem to say only if the system is completely drained and refilled.
As Oldguy 1, I just wanted a litre for the occasional top-up.
Thanks again
Thanks again
For what it's worth, I have been using Valvoline Zerex DEX-COOL Organic Acid Technology Concentrate (Orange color) in my 2017 XE 3.5T due to a couple of leaks out of warranty . It meets the ASTM D3306 rating (as mentioned on the Jaguar product container) and also says that it is recommended for use in Jaguar vehicles however does not explicitly state that it meets STJLR.651.5003. I suspect this is more due to marketing/formal certification rather than the technical formulation of the coolant. I did not have time to completely flush the system before I added this stuff. It looks identical to the Jag formulation and did not cause any adverse effects, discoloration or any precipitation formation and I've had it in the engine for about a year between leaks!
Currently $20 on Amazon for a gallon of concentrate versus the $80+ for the Jag labelled stuff.
Mac Allan
01-13-2016 07:42 PM
