driver seat, clicking sound
Tried to search the forum but was unable to find this exact issue: a clicking sound from somewhere under the electric driver seat (2016 XE 25t). It happens when accelerating, sometimes when braking or turning. It sounds like a small, loose piece rolling back against metal, but I have checked each component under the seat and everything seems to be firmly in place. I noticed that moving the seat fully back, then fully forward, and then to the driving position solves the problem for a few minutes. This is driving me crazy; every time I step on the gas, there it is: CLICK :/ Any suggestions as to what may be the cause?
Thanks in advance
Adriaan
Thanks in advance
Adriaan
I did lift the ducting a bit, without removing it, but found nothing special there. Actually today the noise is gone (for how long I wonder), after an endless combination of seat adjustments, so I guess it has something to do with that. It could also be some part of the seat cooling system, which I have been using. Anyway, thanks for the reply!
Tiberious
02-29-2012 06:42 AM
Surfer-J
07-13-2009 06:46 PM
