DTC Permanent that dealer can not clear
Took my 2017 Jaguar Xe 35t Sport AWD in because every single dtc was showing up on the dashboard. It got so bad that I could not even switch between eco and sport mode. ABS was gone and etc.
Dealer advised that they swapped out the O2 sensor and cleared the codes. Picked up the next day and while driving all the codes came back.
The second time I took the vehicle, I was told that the windshield was not OEM and had to be replaced in order to recalibrate the cameras since those were the only warning lights coming on the second time around. After installing the new windshield they noticed that whoever installed the previous windshield, they
Missing sensor.
lost a sensor and did not replace it.
Now the vehicle is throwing DTCs again. I will attach the picture. Have any of you go e through such an ordeal because the dealership is at a loss of what to do next.
Sent to me by the service advisor.
Missing sensor.
That plug is most likely for the rain/light sensor - has this been fitted yet??
As for the ABS - its logged in PCM and ABS, what did the dealer do with this, did they check it?? Was this code from before as well?
The U0001-81 is logged because there is another control module on the High Speed CAN network giving incorrect serial data - the dealer should be able to see what other modules might have codes, one possibly saying " not configured"
It's also possible that you may have several modules, such as ABS, IPMA and the PCM as shown in the picture are due for software updates
Anthony Zayas (03-31-2021)
Out of ideas
The dealer was able to clear all codes and even checked the entire wiring harness. The codes cleared up for a day and came right back. Any idea what it could be? Is this vehicle known for this issue?
Cleared so far
Well, I went to AutoZone to get a battery check and the reader would stop at 15% when connected. We disconnected the battery and rechecked the battery and it was fully charged and in great condition. Once we re connected the battery, all the codes cleared up. So I'm lost for words now.
They changed the wheel speed sensor so it must be a grounding issue.
Well, drove my car today because the DTC were still on yesterday and today they were gone. This issue keeps getting stranger and stranger. Let's see how long it lasts this time.
