Excessive Brake squeal
Hi everyone, I was wondering if anyone has had any issues with excessive brake squeal. When i’m on the brakes in normal city driving, they will sometimes begin to squeal. It is a little odd however because they will only squeal if on the brakes at a certain amount of pedal. In other words, if they start to squeal if i brake a little more or less than the current point it will stop squealing. This also only happens after the brakes warm from city driving. My car is a CPO 2018 XE S (380 hp) and purchased with only 1000 miles. My current service advisor thinks it may have something to do with the fact the car sat for over a year outside. The car was at a dealer in the los angeles area for a year before i purchased, and was also outside and close to the fires in the los angeles, CA area last year. They have checked the brakes multiple times and nothing is inoperable.
The following 2 users liked this post by vmarrons:
mosesbotbol (08-28-2020),
Stephen.513 (08-12-2020)
I've had this problem since I purchased the car. That 60-0 is to remove glazing on the pads, which does make some sense, but I've had the squealing come back during spirited driving where I'm putting a lot of heat into them. It's really annoying to have an expensive sports sedan squealing like a race car when I pull up to a stop.
vmarrons (08-28-2020)
Received 3,242 Likes
Hard stops to remove the glaze from the brake pads even taking the pads out and roughing them up by rubbing them on a concrete floor helped a bit, but the squeak/squeal soon came back.
Then I found this magic cure: https://www.ebay.com/itm/CRC-05080-D...AAAOSweP9eTOdW
Completely banished the noise forever!
I think I have removed most of the glaze with those hard stops, but just like yours it does come back when driving more quickly. I also thought that maybe it is because I live in a hot climate, meaning brakes work harder? Temperatures right now are often over 90 and have seen 110 fahrenheit.
