Infotainment CRAP , upgrade to chinese multimedia
Hello everyone .
After driving the car for one year with the Jagua crap infoteiment , which is good for nothing and I am not allowed to do anything with it , like the jaguar still own the car and I am just a simple user .
I decided to buy from china a multimedia unit running on android auto with a 10.1" touch screen. It camed with all cables , and more to connect external hdd , 360 cameras, 2 usb , front camera as dvr , etc etc
After install , I noticed in the menu is a "original car" icon and if i click it goes to the old crap infotemeint screen i used so far . Overall I am very very happy and pleased for this multimedia unit , I can install navigation software I want , it has split screen , I can see navigation and a movie in the same time on the screen , etc etc
If anyone want to buy beware, in china are several sellers with several products, NOT all are the same ! 1rst , verify the seller or contact me .
Good luck everyone
Good luck everyone
BruceTheQuai : is chineese brand. they make stuff and then are rebranding it . this is why I said everyone should be carefull before buying it . The seller i buyed from is available , but for 5 units minim order ( even if they aree shipped to different places , but must be ordered in 1 time ) . is moving pretty fast , you would not say is not original equipment. screen is very clear image and touch is very responsive .
I spent 1 day removing the old crap and install this new unit. still gotta make work the reverse / rearview camera ( it switch to camera and it shows steering wheel movement , but i have no image, however in old menu at cameras ...i can see images in rear. might be something from settings , will search theese days ) . it display the air status and seat heating options and phone connections like in old navi . Today I plan to connect rest of wires ( gps antena, 4g antena , the 2 usb input and video inputs .
Mazen Ajouz : Like I said , i hope i can finish instalation today and then I can test the unit to different functions and will post more photos. just let me know if any particular function you want to be displayed . It has preinstalled google maps in real time navigation or syrgic offline navigation. igo and other can be installed i presume .
The following 3 users liked this post by owexonline:
EngshMan : only thing not working properly is , no image when i put in reverse. multimedia switch to black screen and back track of car, but no image. however in the "original car" menu at "cameras" there is image from rearview camera.
Might be a software issue. I am waiting for an answer from the seller, if not.....I will identify camera wires and connect them to "cam" connector of multimedia .
Will let you know about the result in couple of days
Does it have "a rear view mirror" option like an original unit there is a dedicated button it broadcasts the video from the cam no matter if a car goes forward or reverse.
Maybe my english was not corect. In the multimedia there is in menu an "original car " , inside there are submenus ....like the old crap i had in the car , even "cameras" is there. There i can see images from rearview camera .
wheb i put in reverse , multimedia switch automatic the screen to camera and steer track , only there is no camera image , just black screen with colored steer track .
i really don't want to install another camera, at least i use this from old infotaiment.
overall I am more then pleased with this product. Best 1.000 spend in jaguar related items
I installed a similar unit (maybe even the same one) in an Evoque recently.
In the menu of the new unit there was an option for the source of the reverse camera, was two options of "OEM camera" and "Host camera" in order to get the factory camera to work with the new system had to select "Host camera" and then it was working fine.
The installation is pretty straight forward, but there are some issues with the functionality of the new Android component.
Main one being that the calibration position of the touchscreen when displaying the original screens is about 5mm off target, you need to put your finger slightly off target to press the button you want.
The layout/design/styling of the new menus is also a bit chinzy, does not look as slick as the originals, little things like fonts being inconsistent, one menu being a totally different style from another and so on...
They missed out on having Apple CarPlay integrated to the unit, so had to order in an external dongle for that and will need to load a CarPlay app and see how it works.
They are 99% there but not quite perfect.
The following 4 users liked this post by Cambo:
Cambo : it looks similar, and probably is the same , i have no ideea. However what you said about the 5mm display of menu is true, same is happening here, BUT on this I got , image is very clear and still. I would say image is much more clear then in the original display .
I did not find any cam source option yet .... but i will look more .
However I am very happy with this product, and I would make this upgrade any time , I feel sorry I waited 1 year for doing this
Do you know which fires are from rearview camera ? I could split them and take signal from there and problem is solved in 5 minutes
The camera connects to the back of the Audio Head Unit, not to the touchscreen. It is on a shared double fakra connector with the GPS antenna input.
The connection between the Audio Head Unit is only a single 4-pin HSD Fakra connector with a power & ground on the outside of the connector. There is no direct or separate camera signal to the screen, it is all data combined on APIX2 protocol; Automotive Pixel Link https://en.wikipedia.org/wiki/Automotive_pixel_link
IMHO this a problem you need to take up with the supplier of the Android unit, because in the one we had you could select which source for the camera within the menu, and it worked fine.
EngshMan
GPS is working fine. I have installed google maps and sygic offline navigation . I will install IGO which is best maps for east europe .
I also buyed a huawei modem-router with wifi sharing internet connection to feed internet to the multimedia unit.
Will look for screen calibration in the next days . Thanks for the suggestion
Cambo
Thank you for your suggestion, will contact the seller to see if any update is necesary .
Cambo
XJ8JR : it realy works like a android tablet. is capable of multitasking . I did not use a ipod.... i prefer to listen to videoclips, that way ...the other passanger in the car have something to do and let me drive in peace ))
you can watch at videoclip in 2/3 of screen and a navigation software in 1/3 of the screen ( in photo posted up, where is the jaguar sign ....is the navigation, where is other things, it can be videoclip or other movie ).
Radio reception is not worst , and not better then original. i didn;t noticed any difference, maybe is using the old radio ? only display on the new screen ? i have no ideea.
overall i am very happy with this product. I buyed a dvd player , i can attach a external hdd , usb flash drive , dvb-t , dab+ radio and other devices.
XJ8JR (02-22-2019)
