Ingenium engines top mounted oil filter removal
The Ingenium engines have top mounted oil filters which just require the plastic cap to be unscrewed to remove the filter element. However this element is attached in some way to the plastic cap and apparently won't just pull off. The new element is identical at each end and doesn't appear to have any sort of clip built into it. Does anyone know how to remove the element from the plastic cap?
DJS (04-03-2019)
al_roethlisberger
02-07-2017 07:59 AM
Flying Finn
30
12-20-2010 08:14 AM
