Installing aftermarket sports seats in XE S
Hi! Sparco or OMP reclineable seats. I understand the issue is the occupancy / airbag sensor and the fact that the XE S has side airbags in the seats, so removing the seats would remove part of the airbag system... I assume that the answer will be no, you cannot remove the stock seats, but just wanted to see if anyone had done it.
Why do you want to swap the seats out? Are you prepping a track car?
