Jaguar XE Sport R
got jaguar xe 2ltr sport r petrol brand new 67 plate when starting loud rattle in engine sonds like top of engine not getting oil till it heats up fades away when warm but still hear it when reved up rattly noise
Last edited by GGG; 10-09-2019 at 02:39 AM. Reason: My shift key works - take the hint
A 2017 like mine will still be under warranty. Have you taken it to the main agent yet ? Mine is the diesel version, but I think the cylinder head is the same design, or may even be the same. I get no untoward noises at all, apart from the usual diesel growling ! The petrol version of the Ingenium is still fairly new, so this could be an early issue appearing. Pity it has to be the customer that finds these things out !!!
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
the first guy who came out said it was exhaust rattle jaguar had it in not exhaust second guy came out said it sounds like balance shafts rattling jaguar took it in again said petrol not have balance shafts I said ur own tech guy came out said it was he said it sounded louder than his landrover defender on start up so im back to square one have bn on forums and couple jags had faults with balance shafts and balance shaft censors so will need to battle on see what happens never thought id get this prob from jaguar company
I don't think the Ingenium engines have balancer shafts.
Essentially you have to put your foot down now, and tell them you want the problem fixed ! They warrant their cars, so let them fix it. If they do the Microsoft trick of saying "its not a bug, its a feature", then I'd be making big noises.
They are here as member "CRC@Jaguar", so why not send them a message.
anyone from jaguar on here want to look into my problem thinking of takin it to independent garage to get looked into might have more luck as jaguar seem to be giving me runaround iv grown up with cars all my life not a expert in any form but know when a engine not sounding right especialy a new one
It's been described as a rattle, tapping, ticking, sewing machine noise, etc. Most of the time it comes down to a faulty earth strap that's too rigid and transfers fuel pump noise to the passenger cabin. There is a TSB for it...JTB00483V4
https://www.xeforums.co.uk/viewtopic.php?f=19&t=4638
https://www.xeforums.co.uk/viewtopic.php?f=19&t=6351
mosesbotbol (10-13-2019)
Keep in mind that most direct injection engines will make this noise when listening from outside the car. The TSB is to keep that normal fuel pump noise from being directly channeled in to the passenger compartment. My dealer didn't know about the TSB either until I asked them about it.
ETA: If your car is brand new it may not be covered by the VIN range stated in that TSB. There are still guys that have had success replacing the earth strap even when the dealer said the TSB did not apply. In the threads I posted above you can find a "Halford's braided earth cable" fix that seems to do the job even when the official Jag fix fails.
https://www.halfords.com/workshop-to...y-cable-22cm-9
