Jaguar XE wheel spacers
Anybody have wheel spacers on their XE and which ones did you get? I had hubcentric slip on spacers on many cars but Jaguars are different since they have the studs.
I was thinking about 15mm but I noticed that the oem studs are longer so how do you fit spacers on those...what did you do.
There's a thread going on in the F-type section about group buying spacers. I'm fairly certain those same spacers would bolt up to the XE without issue. The bolt patterns are identical.
Also, I found these a while ago and thought about doing it. Never got around to it though...
https://www.uswheeladapters.com/shop...wheel-spacers/
Today I installed H&R 15mm spacers on rear of my 2018 XES. You do have to remove about 1/4” of each stud, but that is only blank unthreaded part of stud. Cut them with a cutting wheel. Always make sure to have a nut on each stud to protect the threads.
be warned to use quality spacers. I tried two different sets off eBay. Absolutely crap quality and soft nuts that strip and ring off. 15mm does seem the max I could go with the 9” wheels and 265 rear tires. Going to try fronts soon.
