JLR Mechanic in Orlando FL
Are you able to PM me what your dealership is currently quoting for AWD service? Are rear and front diff serviced together at a quoted price or are they listed separate? How about the transmission (which jag says is not needed)? Is the transfer case as separate service from the ones I've listed and if so, how much? Also, i know for the ZF tranny its lifeguard tranny fluid, what specs are used for the diffs and transfer case? Alot, I know! Thanks Loth - owner of a new 18 XE S.
