New XE Owner
First, it is a great car and the v6 is wonderful. It pulls and pulls. I also have the VAP tune (stage 1) and will agree they are excellent. I do not track the car but I do drive it like a teenager! A teenager lacking the sense God gave a shovel! Lots of fun!
The only real issue is that the cooling pipes (early welded plastic type) are subject to splitting. I have these pipes and am at 65k miles with no issues, but am shopping for a good mechanic to replace these proactively.
thank you for your two responses! I’d be willing to throw a new set of hoses on there myself. Do you guys know if any good kits? Maybe some upgrades kits. Also, the vehicle has a camera fault and doesn’t show a rear camera when in reverse. Normal issue? Or just a camera problem of some sort. Thank you all so much im Super excited to purchase it
Prange (06-25-2023)
noted I appreciate it. I’ve found the coolant tubes and they don’t seem horrible to replace. So that should be in the next week or so
Prange (06-25-2023)
This post https://classicairheads.com/blog/202...r-replacement/ from gfp@classicairheads.com(thank you GFP!!) helped me out no end when I had to replace my coolant pipe(s). I wish I'd have done the rear crossover heater pipe (p/n AJ814053) at the same time I did the one under the supercharger. The supercharger has been off twice now. I did learn after the second time that there are some brackets at the rear of the supercharger that didn't need to come off. This saved me a good hour or more since the bolts for the bracket a pretty awkward to get to.
I also had some issues with the little plastic connection that comes out of the front of the water pump. I drilled and tapped my water pump and put in a threaded fitting and used a new piece of hose.
Hope this helps some.
