No Media Player...
No Media Player...
So, after reading about how this car can rip CD's and import USB I figured I'd give it a go...
Connect my USB hard drive, select Media Player and nothing... Doesn't see the drive. Press eject on CD player, nothing happens. I figure, "let me at least try ripping a CD". Put in my favorite Clash CD and nothing... Media player says no media. Press eject on the CD and nothing happens again, but I get an error message which escapes me...
CD is stuck... Will try a 2nd USB and see if that works. Have appointment with local dealership to straighten this out.
I am also unable to increase the volume of the front/rears sensors and NAV voice...
Do you use a same USB port that's inside the armrest compartment?
If so, I would recommend formatting the HDD as FAT32 (you will see that in formatting options if you are using a Windows OS). It might be formatted as NTFS by default and Jaguar system will not detect that.
I use USB Flash drive as my media player and after formatting it properly, it works well. The system sees all the folders, artists, and songs that I have ripped on USB Drive
As for the CD, my car does not have a CD changer thus I'm not sure how to resolve your issue.
The media player kind of is working now. Was able to rip a CD, but it did not copy over title/artist/song and give no indication when the CD is complete unless you try to eject and get a prompt.
Formatting to FAT isn't going to work as you can't (as far as I know) just format back to FAT from NTFS; the other way is supported.
Will have to check my drive to see how it is formatted...
Dropped car off at the dealer today. Service writer thought some or most of my issues could be solved with software update.
Some other issues I have:
- Maine is default search state in Nav
- Seat heat should be automatic if freezing out (not sure if that is a fix or not)
- Nav and sensor voice/tones are too low and can't raise them
- Dialog box for account info in Nav keeps popping up (don't want that)
It's not increasing in volume when I do that, nor do I want the music blasting that loud so I can hear the voice when it comes up. Never had an issue with voice on my other JLR cars...
When I ripped a CD, the artist info did not get populated; that is another issue along with knowing when the rip is complete on the screen...
So, the dealer thinks my issues are all software related. They also said Jaguar has a "recall" where a new steering wheel piece is needed for "telemetry" display and I will need to bring my car back for that...
That being said...
They had my car 3 full days at the Jaguar Sudbury dealership, no loaner car... They deliver the car to me filthy and with low windshield washer fluid warning. I had to use my own fluid and was over a gallon and still not completely filled.
So much for new Jaguar customers getting an even average dealership experience when servicing a car. When I owned a Honda, the dealer would wash it and have a loan car for me if was a whole day; never mind 3 days... They didn't even tell me when I dropped the car off that it would be more than a day. I would've rescheduled...
Every time I go that dealership or the Rolls/Bentley, Lambo dealer next door (just browsing)... I keep hearing how Herb Chambers has 50+ dealerships and customer service is a big deal... 50 dealerships and you can't get me a loaner or get me rental? Service writer implied I should rent my own car...
Jaguar is one of their fanciest marques. The owner's son manages the place and they can't get me a rental or loaner??? They did drive the car to my house (7 miles away) to drop it off last night, FWIW at 7:00 PM.
I haven't had a chance to see if things are fixed. Had to wash the car myself this morning. Not sure how to set the light load tire threshold now. I don't want it alerting that I am below the normal load threshold. I had it set before for light load.
That being said...
That being said...
That being said...
They never vacuum it or wash it. I always have to make an appointment 2 weeks in advance to get a loaner otherwise no chance of getting one. They do not pick or drop off cars in Brookline/Allston area. Their shuttles only go for 5 miles. The service adviser always seems like being in a huge rush, not having enough time to listen to what concerns I have about the car.
They refused my 1st oil change at 7K miles telling me "this is a new car, you can drive 15K miles without an oil change". They are as cheap as it gets. Even the pastries they offer at reception are always old.
The problem is that Norwood is even worse. My friend had a horrible experience with them when he had F-Type R. I've not tried Peabody but I would expect it to be just as bad.
That being said...
That being said...
I honestly would expect nothing less than that and would go to another Jaguar dealer if there is one.
8 miles vs. 30 miles in suburban traffic? It's a tough call. No guarantee on better service at other JLR dealers. I haven't heard anyone rave about any MA JLR dealership service department.
They're very pleasant to deal with, returned my calls quickly and are very courteous. They also installed my metal pedal caps
The one close to my house never bothered to call me back, I had to call them twice to find out they had no loaner available.
Good thing there are 5 Jaguar dealers in the Chicagoland area.
And I will happily drive more to a dealer with better service who get the job done right the first time.
Never. Just the one near my house in Sudbury or Woburn when they were around. Went once to Lee Jaguar and that was mistake. I believe that evolved to be Jaguar Sudbury.
Where did the Woburn Jaguar mechanics end up? I want to go with them, lol... Previous Jags were out of warranty and usually went to Samuel's in Brighton.
Next service requirement I will weight what is being done and decide where to go.
Agree. I hate bringing my car in for service too.
