XE ( X760 ) 2015 -
OEM Tires (Tyres) on 2017 XE 35t (19")?
Old 09-26-2022, 04:50 PM
Kevin93940's Avatar
Default OEM Tires (Tyres) on 2017 XE 35t (19")?
Hello everyone -
What were the OEM tires on the 2017 XE Prestige with 19" wheels (in North America if that matters...)
Thanks!!
Old 09-26-2022, 06:04 PM
Fraser Mitchell's Avatar
Received 2,456 Likes on 1,952 Posts
My 2017 XE Portfolio AWD came with Dunlop tyres on its 19" wheels. Whether cars supplied to the US had different tyres I can't say. They lasted well, but are prone to shoulder cracking which requires them to be replaced, even if not fully worn to the UK roadworthiness test limit (1.6 mm). I had to replace the fronts for this reason, and a year later, the rears.
Old 09-26-2022, 07:21 PM
jgearheart's Avatar
Front:
225/40ZR19 93Y 7.5Jx19 ET45
Rear:
255/35ZR19 96Y 8.5Jx19 ET55
Old 09-26-2022, 07:31 PM
jgearheart's Avatar
Pirelli Centurato P7 are the actual tires, if that's what you were asking.
Old 09-26-2022, 08:55 PM
Kevin93940's Avatar
Thanks and yes. I was looking for the manufacturer and model.
Surprised to see different sizes front and rear.
So “rotation” is just R-L…
Old 09-26-2022, 09:15 PM
jgearheart's Avatar
Yup. Mine is an AWD, but I'm fairly certain the RWD have the staggered 19s as well.
Old 09-27-2022, 07:02 AM
Richb55's Avatar
can’t rotate if there directional tires rotation designated on tire with arrow
Old 09-27-2022, 07:46 AM
OldGuy1's Avatar
My 2017 R-Sport 35T came with "staggered" wheels and therefore tires as standard equipment at least in the US. The sizes and brand are what jgearheart listed.
Old 09-28-2022, 08:33 AM
NewLester de Rocin's Avatar
Yeah, rotating the tires has always been a controversy on the XE. Jaguar's Owner Handbook instructions often say do NOT rotate these tires at all. Wear them until either rear of front are facing the end, and swap ALL four out at the same time.
Can't remember which handbook I read that in, but it is definitely in one somewhere.
Old 09-28-2022, 05:49 PM
When I had a 1980 XJ6 Series 3, the maintenance manual warned against rotating tyres, stating that they should be replaced as a car set. Of course this was nonsensical, as tyres on the front or rear could be worn out well before those on the other axle. It was a council of perfection without any consideration of owner economics. For myself, I work on the basis of replacing in axle sets. So, for instance, when I suffered complete tyre destruction on one of the rear tyres on my MG TF in April, I replaced both tyres.
Here's a photo of the tyre
Old 09-29-2022, 11:49 AM
DJS's Avatar
DJS
DJS is online now
Received 2,123 Likes on 1,418 Posts
Aww, you could have patched that.
Should anyone be interested, the 18” wheels are ‘square’ - same size all round, not staggered.
Old 09-30-2022, 09:06 AM
jfxobrien's Avatar
Interesting. What is the square setup and I see you say you have AWD? my guess is you'd have 225/40/18 all around?
I would like to track the car but 225s all around are narrow, so I'd love to find out what an acceptable wider width would be on the fronts - and then use that all around with a nice sticky compound.
Old 09-30-2022, 11:54 AM
DJS's Avatar
DJS
DJS is online now
Originally Posted by jfxobrien
Interesting. What is the square setup and I see you say you have AWD? my guess is you'd have 225/40/18 all around?.
I’m on the road right now, but that sounds right.
Old 09-30-2022, 04:28 PM
Amazingly, the wheel was totally undamaged !
Old 09-30-2022, 08:16 PM
Richb55's Avatar
Default Dealer installed tires. 2019 XE AWD
bought a used Jaguar , requested the dealer ibsff to all 4 new tires. Their Choice : Continental
pro contacts all around. 225/45. R18’s
very quiet tire with a nice ride Tire pressure was a bit puzzling fronts at 43 psi in fronts. 47 psi in rears. Anybody know why such high pressures ?
Old 09-30-2022, 10:21 PM
booklaw1's Avatar
This may not be the official answer, but when I used the lighter setting (for less weight inside the car), I kept destroying tires and rims every time I hit a pothole. Someone later explained to be that with less air in the tire, there is less distance between the car and the road.
Since I switched to the 43/47 setting, I have not experienced any ruined tires or rims.
Richb55 (10-01-2022)
Old 10-02-2022, 09:20 AM
DJS's Avatar
DJS
DJS is online now
I found that while 43/47 was good for handling, I could feel every imperfect expansion joint on freeways. I set TPMS to ‘light’, and run 40/40.
I also dislike how close the rears get to the tires’ max cold temp pressure of 50.
Old 10-03-2022, 09:07 AM
Richb55's Avatar
how to reset TPMS TO 40/40. Easily done ?
Old 10-03-2022, 02:16 PM
fireblader929's Avatar
Except for buying two new Pirelli Centurato P7's after a pothole took out both left side tires with only 2000 miles on the car I never went back to them. The sidewalls on the Pirelli's seems to be weaker than other brands. Since the Pirelli's I've tried Michelin Pilot Sport 3+ A/S, then Goodyear Exhilarate (which were pretty good despite the cheesy name), but my favorite so far are the current Bridgestone Potenza RE980AS+ which are still comfortable at the higher 47/43 psi setting. Similar to what DJS mentioned though...I tend to run them around the mid-point of the TPMS normal/light setting of 42/40... but set the TPMS to the light setting to avoid warnings. We have big morning/afternoon temperature swings where I live and so I can often see 50+ psi on the rears if I use the 47 psi setting.
Old 10-04-2022, 06:46 AM
DJS's Avatar
DJS
DJS is online now
Set TPMS to ‘light’, which is something like 33/33. It doesn’t seem to care about higher pressures, only lower.
Quick Reply: OEM Tires (Tyres) on 2017 XE 35t (19")?
