So I plasti dipped my rims last weekend and the front bumper wind breakers a couple weeks before that. I think they look great considering I really disliked how originals looked and was not going to shell out what dealer wants for an upgrade. Total cost about $30.
Well taping the wheels and attaching newspapers around wheels probably took the most work, I would say an hour to two. The spray itself is a lot easier then I thought it would be and plasti dip is very forgiving. Couple times it got a bit too cold and started shooting bigger blobls, quickly adjusted the issue by warming the can up in warm water or just shook the can better and sprayed again. The dots kind of disappeared on their own after that. The wheels look perfect, like straight from factory. I did wait 20 to 30 minutes between each coat and I did 5. So that took about two hours but I did other work around the yard in between coats.
