Passenger side water ingress
Hello fellow Jaguar owners! I have water ingress on the passenger side floor board. I have been trying to figure out where it is coming from. I noticed inside the hole is wet and looks like it is holding some amount of water. When i poured water on the windshield, it drained properly to the ground. The one thing i do know is it is rain water as the liquid is clear and has no odor to it. Jaguar wants to charge 250 just for the ingress test, and then whatever it costs on top of that to fix the problem. I want to try to do whatever I can first before going that route. Any help or tips will be greatly appreciated!
I'm not familiar with the XE other than having had them as courtesy cars from the dealer but a general comment on water ingress may be of help.
On several other Jaguar models, water in the front footwells (can be either side or both) is often caused by blocked or detached AC drain tubes. The condensate can't drain as normal below the vehicle, backs up in the drain tube and flows into the passenger compartment. This is a lot more common that leaks through glass or door seals.
Have a friend or a relative run water to the windshield or suspected areas via garden hose and while you are inside the car observe where the water is coming from.
Or some possible leads from XE owners in the UK https://www.jaguarforum.com/threads/...otwell.137234/
psyo
04-20-2022 03:37 PM
buickfunnycar.com
11-21-2014 11:16 PM
