Pedal falls halfway then engages brakes
I have a 17 XE with the 3.0 and AWD. I removed my brake pads to sand down the top layer cause they were squeaking. I work in a shop and we’ve done this for years. No issue. After I put my jaguars front brakes back together. The pedal goes about halfway then starts to engage the brakes. I’ve bled the system by pumping the pedals. I’ve bled them with a pressure machine from the reservoir. . I’ve bled them with vacuum from the bleeder screw. I’ve replaced my front brake hoses and bled all the brakes again but still to no avail. I’m close to taking it to jag. Any help is appreciated
