XE ( X760 ) 2015 -
Project 8 walk around
Old 12-22-2017, 03:33 AM
dave_Sw1's Avatar
Default Project 8 walk around
Saw one in the flesh at laguna Seca, gorgeous
Old 12-22-2017, 10:36 AM
mosesbotbol's Avatar
Received 1,202 Likes on 933 Posts
I would've expected it to have fancier rear calipers. Just look like the stock ones painted.
Old 12-22-2017, 11:14 AM
zach05855's Avatar
From my spec sheet.
BRAKES, WHEELS & TIRES
Carbon Ceramic Braking System
Project 8 offers the latest Carbon Ceramic Braking (CCB) technology as standard. Consisting of new 6 piston front calipers with 400mm Carbon Ceramic discs and 396mm Carbon Ceramic discs for the rear, Project 8 delivers enhanced levels of sustained braking performance under demanding conditions. To best utilize the high performance Carbon Ceramic Braking System, Project 8 will employ a synthetic racing brake fluid which has an exceptionally high dry boiling point, making it ideal for use under extreme braking conditions such as those experienced on track.
Old 12-22-2017, 12:36 PM
Originally Posted by zach05855
From my spec sheet.
They could it be the regular XE rear caliper with carbon disks and pads, no? Looking at the F Type SVR, the rear calipers are what I would expect on the Project 8. That is not what is in the OP's linked video.
Could it be the production Project 8 will have the SVR's brakes?
Old 12-22-2017, 07:50 PM
alphakinase's Avatar
You're right mosesbotbol, those rear calipers do look a little small! Odd!
Old 12-22-2017, 11:04 PM
zach05855's Avatar
This is not a final production car. The actual final production car will probably have different components. This car is likely just for the show circuit.
Old 12-22-2017, 11:14 PM
zach05855's Avatar
There are still a lot of TBD for this car.
TECHNICAL SPECIFICATIONS
SPECIFICATIONS XE SV PROJECT 8
Engine Capacity (cc) 5,000
Configuration V8 Supercharged
Power (hp @ rpm) 592 @ 6,500
Torque (lb-ft @ rpm) 516 @ 3,500 - 5,000
Valves per cylinder 4
Compression ratio TBD
Bore/stroke (mm) TBD
Fuel tank capacity (L) 63
Final drive ratio TBD
Suspension - front Double Wishbones, Adjustable Coil Springs, CVD Dampers
Suspension - rear Integral Link, Adjustable Coil springs, CVD Dampers
Brake Type - front/rear
Carbon Ceramic Disc Six-Piston Caliper /
Carbon Ceramic Disc Single Piston Caliper
Brakes - diameter front/rear (mm) 400 / 369
0-100 km/h (sec) Target of 3.7 (TBC)
Top speed (km/h) 322
Length (mm) 4,713
Width (excl mirrors) (mm) 1,954
Width (incl mirrors) (mm) 2,075
Overall Height (mm) 1,436 / 1,421 (Track Mode)
Wheelbase (mm) 2,835
Front track (mm) TBD
Rear track (mm) TBD
Turning circle - curb to curb (m) TBD
Curb Weight (kg) TBD
Leg room - front (mm) 1,055
Leg room - rear (mm) 889
Head room - front (mm) 970
Head room - rear (mm) 947
Shoulder room - front (mm) 1,442
Shoulder room - rear (mm) 1,389
Trunk space (L) with tire repair kit 450
Johnny Mayday
I-Pace EV
07-27-2017 05:53 PM
powerhouse
01-06-2017 07:07 PM
Quick Reply: Project 8 walk around
