Silence after shut down
One thing I noticed right away about our XE was that after shutting off the engine I could hear a small pump running. Presumably, the pump is circulating either oil or coolant to the turbo - never checked to see what it does. I realized the other day after shutting the car off that I did not hear the pump running. I checked again a couple of times and, even after longer trips, still no pump noise emanating from under the hood. Our weather is now much cooler in PA, so not sure if the after cooler function is connected to outside air temp or what the scoop is. Anyone?
marco_hevia
09-09-2011 08:02 AM
