South Florida Jag Mechanic (installed crank pulley today)
After purchasing the tune and crank pulley from Velocity AP, i started looking for a Jag mechanic in South Florida (Fort Lauderdale/ Miami area). I ended up getting it installed today by Ron at Garic Auto (Hollywood, FL)
From the forums and online searches this my list of potential mechanics in case anyone needs the same info. I called each shop to see if they did performance upgrades, and if so how much to install the crank pulley on my 2017 XE.
Doug’s (Gables Cats)
Hope this helps any of my local jaguar fam!
- Gables cats no longer in business but Doug still does some work on Jags
- said $680 for install
- only maintenance and repairs
- no answer
- has done XK but not XE. Said to come by and he’ll check. $150 hour usually 2 hour job
- doesn’t work on models past 2010
- found his info from here, jagforums
- Talked to Ron
- He’s done pulleys for many of the 3.0 and 5.0 Ranges just not XE (til mine)
- Quoted me $100-$150
- Very knowledgeable about AJ engines. Asked if coolant hose has had issue and warned me about water pump (had both of mine fixed under CPO warranty) so this immediately made me confident he was the guy
The following 2 users liked this post by theBunMan:
Anthony Zayas (03-01-2021),
Panthro (12-21-2023)
The pops & crackles are requested when purchasing the tune, and VAP can send you a file with and without them enabled if you want to try it out.
The exhaust remains the same for the most part (you can request a higher rev limit with the tune). The crank makes the supercharger spin faster so there's a slight change in that sound.
The following 2 users liked this post by CSL:
theBunMan (03-01-2021)
lifted.n.lowered (03-03-2021)
that is correct. no change except for slighty more supercharger whine. but even that that is only when you are really pushing it. I didn't enable pops and crackles either but might request it just try it out once or twice. i definitely don't want it on all the time though and iv read its not great for the catalytic converter anyways.
i always read that, and to be honest did not notice much of a difference from stage 1 and 2. i even brought out the dragy to time some 0-60 and 0-100 and my numbers only slight improved (and this is probably only because i just got brand new tires and my old ones were bald). I wonder if my stage 2 tune that was preloaded was messed up, and is the same as stage 1 somehow. does it take time for the ECU to relearn? idk but i do know that it should have been a dramatic difference
gonna reach out to stuart though as iv heard his customer service is great and see why i might not be noticing the gains so much.
In my case the results were clear. I went from stock (340hp) to Stage 1, then a week later to Stage 2. Dragy testing results (0-60mph, verified, all times including 1ft rollout):
-Stock: 4.89 seconds
-Stage 1: 4.33 seconds
-Stage 2: 4.14 seconds
I am AWD with stock Pirelli P7 All-Season tires. I am planning on getting Michelin PS4s once these go bald and I'll re-test. The VAP TCU tune has allowed me to have more consistent launches as all my best times were in manual mode to hit 7K, and now "S" shifts at 7K post-tune.
With paddles I can now rev past 7K with the TCU tune; once I have some time I will see if I can get even closer to that 4 flat/sub-4.
Outside of 0-60, the torque is much more present throughout the entire rev range, and in "go to jail speeds" (only done in Mexico) the car keeps pulling hard. Stock it just fell flat.
This is, of course, my own personal experience. Butt dyno plus the available Dragy data. I haven't tested 1/4 mile yet. Once I do I can at least compare it to magazine numbers.
The following 3 users liked this post by CSL:
absolutely go for it. The number of people that say the difference is massive far outweighs my experience. And there might be a simple reason for my lack of gains.
