Squeal after long parking, low speed
The car developed a high pitched squeal after being parked for a while. It disappears after sudden acceleration or sudden braking. The squeal only present when the tires are rotating. Anyone experienced this issue?
I found something almost identical:
Received 2,670 Likes
Its 17, AWD 180 D, 18k Miles on ODO. No, nothing needed to be worked on except 3 alignments within 1.5 year period. In both cases on videos those people don't press the brakes neither do I. The noise appears when the wheels turn. If I accelerate coming out from a garage ramp and stop suddenly the noise disappears. My brakes squealed from day one, not loud but like a mouse.
I have noticed squeaks and squeals occasionally after a car has sat for long time, and sometimes even overnight when the weather turns cold and damp. The brake rotors develop a coat of surface rust and the noise disappears as that surface rust wears off, usually within the first two or three applications of the brakes. If its particularly obnoxious, I'll drag the brakes the first 100 feet or so to rub it off quickly. Some cars are worse than others and some never do it at all. It could be attributed to the brake caliper design or the rust-resistance of the rotor material. Before you drive it next time, look to see if the rotors look orange. Maybe roll the car back a couple of feet and look to see if there is a patch of rust underneath where the brake pad was. Then as soon as it stops squeaking, get out and look to see if they look clean.
Yes, they are rusted orange. Sometimes the car sits 2 days sometimes 5. I noticed that the rust started showing up around the rim lug nuts too, but easily can be cleaned. Never had a car the rust would be in this area. I'll keep you guys posted.
All brake discs rust to a certain degree when left unused. However, the Jaguar XE (and maybe other Jaguar) discs do seem to be more inclined to rust significantly after only a short time (like just overnight). This explains why a number of XE owners have complained that their discs needed replacement after only a few tens of thousands of miles (sometimes as little as 10,000 to 15,000 miles). I've never had this problem with other cars and can only assume that Jaguar must specify an inferior (and maybe cheaper) quality steel for their discs. Disappointing for what is supposed to be an up-market car.
This is uber nonsense if a car needs a disk replacement at 10,000-15,000 miles. Also, I don't even use the brakes that much and don't ride them in the traffic. I don't like the fact something major needs to be replaced that soon which is unlikely will be covered by warranty. My main concern is that the vehicle needs to be serviced by some amateur-careless mechanic at Jaguar or contractor. I already had a bad experience, and it was not something serious. For now the noise is gone. If it comes back I'll take the car to a dealer.
If its squeak, squeak, squeak, that means the rotor is no longer perfectly flat. But no rotor was ever PERFECT The squeak squeak just gets louder the worse it is. They measure the "runout" with a dial indicator and if its out of tolerance, then they will replace the rotor, but only if its beyond a safe tolerance. If it's squeeeeeeeeeeeeeeeeeeeeeeeeeeeeek, then it's just rust and the rotor is fine. They will not likely replace it. But rust alone doesn't make the rotor get out of tolerance. That usually happens because the rotor was overheated. Maybe a parking brake stuck on or somebody drove down a mountain road with their foot on the brake the whole way. The rust squeak only served to alert them to the fact that something was wrong. But if somebody complained of any kind of brake noise at 15K miles, I can see a Jaguar dealer offering to replace the rotors just as a goodwill gesture. At that point, the lease is probably about due and they're hoping new rotors will quiet it down long enough to lease them a new model.
Just to say that when I bought my 2017 reg XE in January 2019, at 10k miles and still under the original warranty, I noticed some steering wheel shake under braking, so took the car back for a check. They came back, (Jaguar main agent near where I live), and said disc runout was within tolerance and anyway, the warranty didn't cover brake wear and tear. Of course I immediately said - "yes, but it's Jaguar that sets those tolerances" . I didn't go in all heavy, and said that I was prepared to pay something as the car had already done 10k miles but didn't think I should pay the lot. So we agreed, and new Jaguar front discs and pads were fitted, but when I came to collect the car and pay my share, they said there was nothing to pay, it was done under goodwill. Now, here's the thing, those discs and pads are still on the car and its done 30k miles, so 20k since fitment. No shudder on braking and from what I can see everything is in good order. The pads produce very little dust at all, so I am well pleased, as the 2007 XJ I had previously always needed frequent wheel cleaning due to brake dust.
AZBob (12-12-2020)
