Wife was interesting in the XE, but she wants remote start!
So my wife and I were looking at the new XE for her and she wanted to know why is it that less expensive cars offer a remote start and a Jaguar doesn't? I can't say I blame her, it is a nice feature to have on a cold winter day.
The dealer said that if we have one installed - goodbye to the warranty. And he will not install one either.
Thoughts?
Thoughts?
What dealership did you go to? I notice you're from NJ as well. AFAIK, XE works with the Remote app, so as long as you have a smartphone, you have remote start. I start my car from inside my place of work and set the temperature. Also gives you a GPS location, beep and flash and allows you to lock/unlock. Sounds like the dealer was BS'ing you. My dealer helped me set up the Remote app on my phone!
The remote start from the smartphone app is only available for cars with automatic transmission, but as (I think) there are no manual transmission XEs on sale in North America that should not be an issue. There is also a remote heater which is an option that is separate to the remote start and works from the key fob but I don't think that is available as an option in the US either.
If it is any consolation, in the early months after launch many UK dealers also knew very little about the car they were selling.
Thoughts?
Thoughts?
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Edit: the message disappears quickly (within couple of seconds) so you have to stare at the app constantly. Most common causes: the car is not locked, or (in my case) the windows weren't up. Or so it thought
It should give you an error message stating why it didn't start. That should give you an idea.
Here is how to do it:
This usually happens because somebody disconnected the battery and the settings for the windows were lost. In other words, the car needs to re-learn where the limits for the windows are. This is very simple to do.
Your switch has 5 positions. We'll call them:
"-2" which is the switch all the way down for automatic down
"-1" which is the switch slightly down for bringing the window down manually
"0" which is the switch just sitting on its normal position
"1" which is the switch slightly up for bringing the window up manually
"2" which is the switch all the way up for automatic up
The reset procedure is very simple:
Shut the radio off and other source of noises, you are going to be looking for a little "click"
Hold the switch of the window you wish to re-teach the limits in position "-1". Even after the window is all the way down, keep holding it and listen for a little click. When you hear it go to the next step.
Hold the switch on position "1". Again, even after the window is all the way up keep holding it and listen for a "click".
That is it! Simple enough huh?! Repeat for all windows and you are all set!
The windows were all up and the car has not remote started on a few times with no error displayed.
I am afraid to bring to the dealer as they'll keep it for days with no loaner car. I'll give the remote app another try today to verify if there were any error message.
The app is poorly designed. If you press the start message, the screen should change to say a start request is pending or something...
I've had several "interesting" interactions with Remote App with my XE. I've found that sometimes the first time you open the app it says it has "updated" but really hasn't. When it shows the car still parked at home while I'm at work, I stop the app, completely kill it on the phone and then restart the app. Other times I've pressed the map on the opening screen and it updates in full screen mode to the current location.
In my use, the application is accurate on location and current car status. Trips look to be accurate as well.
Next time I want to remote start, I will try disabling wireless on the phone first. I wonder if that is what's f-ing up the remote start? App things the phone is not on cell network?
Is that the latest app version? I've gotten "can't contact the vehicle" message several times before but I'd say the app still works 8 times out of 10. Sometimes it has trouble when there is a bad wifi signal or bad reception.
They released a new version of the app a week ago or so, maybe try that one out?
As for the dealer and no loaners, I learned my lesson, I call and ask when will a loaner be available (usually week or two wait) and then I schedule the service.
I'd remove the app and install it again. Maybe this will help
Hmmm... Looks like something is wrong with your app. Because after I press Start button and enter PIN it does show status "Contacting vehicle" and the "lights" around Start button start spinning. Then the little engine icon appears.
Just to be more specific the car has to have the navigation package, without there is not infotainment and no app option.
