Wife was interesting in the XE, but she wants remote start!
My app hasn't worked since 12/2016 and JLR and the dealer blame it on the iPhone 7. I got a Android phone and its the same problem and now they won't even answer my calls.
I tried it down myself to a JLR cloud sync error on the JLR side with my account and they need to fix this already. The only info I get out of this app is the gas and mileage status. Everything else keeps saying its in sleep mode and will wake up on the next drive.
mosesbotbol (03-07-2017)
https://incontrol.jaguar.com/jaguar-...wner-web/login
Edit: also you may try to remove your car and add it again.
I can log in and all my info is there but I see this and the tab doesn't exist to enable.:
LATEST JOURNEY
Journeys Disabled
Journeys has been disabled. When Journeys is enabled, details of your latest recorded journey will appear here.
To enable Journeys, click on Vehicle Settings, select the InControl Protect tab and use the Journeys switch.
LATEST JOURNEY
Journeys Disabled
LATEST JOURNEY
Journeys Disabled
LATEST JOURNEY
Journeys Disabled
Right above the "LATEST JOURNEY" there should be a name of your car. When you set up the account initially you should have named your car somehow (ex. mine is named Jag). If it is not there then something is wrong and try to add it again. On the same page in the upper left corner there is a button called "Add Vehicle". Click on it and go through the procedure of adding your car.
If you already did it then first remove your car and add it again.
To do so click on the Vehicle Settings button (right to Add Vehicle button at the opposite end of this bar) and click on Remove Vehicle. Then go through the procedure of adding your car again.
Hope this helps
