XE Battery Replacement
The battery in our 6 year old XE is on it's last legs. With the placement of these batteries and the stop-start system, I'm not sure where to go at the moment. I have a local battery guy or should I let the dealer supply and fit a new one? Cost is not really the issue, I just want it done right. I know it's just a battery, but I have not had cars with so much tech, the battery in the boot or a vehicle with stop-start to consider.
![](https://i.postimg.cc/C514RzkP/IMG-4893.jpg)
Any opinions would be greatly appreciated.
If you take it to the Battery Guy just make sure that he doesn't absent-mindedly shut the boot (trunk) lid while the battery is disconnected. If he does, they'll be an enormous problem getting the lid open again because JLR (in their wisdom - or because of nickel & dime cost-cutting) didn't see fit to put an emergency key release on the lid!
And that's a reason to replace a battery that is showing signs of failure before it actually fails completely - which can happen to modern batteries seemingly overnight.
I've found that connecting up a CTEK charger (with AGM compatibility) at intervals to the connection points under the bonnet/hood is sufficient to keep my XE battery in good condition. There is no need to disconnect the battery or remove it from the car as recommended incorrectly in some versions of the JLR owner's manual. JLR's other advice that "only skilled technicians should charge the battery" is contradicted by themselves selling a Jaguar branded CTEK charger as an approved accessory (at about twice the price that CTEK ask for!).
The CTEK cannot overcharge the battery, even if it is left connected, because once the battery gets to full charge the CTEK goes into maintenance mode, applying just sufficient charge to keep the battery fully charged.
DB20 (07-04-2021)
![](https://i.postimg.cc/jjWt78j0/IMG-6759.jpg)
The cold winter and it's age has caught up to it, charging it on the CTECK is just not doing the job now. Hoping the new battery arrives on Monday.
An alternative, these Braille batteries will save you 40 Lbs vs our car's oem and large heavy (50lbs) lead battery. Many people may be interested in in a marginal but 24/7 performance and gas mileage improvement. It comes at about $1000.00 though, instead of the $269.00 for the lead acid. But...considering the Lithium Ions last 10 years or longer, you'd have to replace at least 2 of the old style batteries in the same period so the long term total battery costs of each technology works out to be more similar than first glance.
https://motoiq.com/saving-an-easy-35...aille-battery/
Consider this...40lbs weight savings represents 1/100 of your car's weight. If you count gas mileage improvements (say you save 3 cents a gallon), engine wear costs, and braking system costs, it just might be worth it to get a modern lightweight battery instead of the antiquated battery technology of the 50's.
Not to mention the improved handling.....faster acceleration...and shorter braking distance. I noticed the difference after losing 40lbs of dead weight, for sure.
DB20 (07-13-2021)
After a bit of a run around, I finally got a new battery in the Jag.
![](https://i.postimg.cc/QtWNVzSK/IMG-0276.jpg)
I rang the dealer and asked if they could quote me a price, and to leave me a message as I would be working. The message arrived to advise me a windscreen supplied and fitted would be $2985. Windscreen?! Cue me calling again to say that I was pretty sure I had asked for a battery not a windscreen. Anyway, I was quoted a price and the battery was ordered, with a two day turn around.
Seven days later I was advised the item was in stock and that I could come in any time to have it fitted. Fine, I'll be in tomorrow. I was then phoned an hour later to advise that the they had been sort delivered, the paperwork said it was there but the battery had not been delivered. Another seven days, the battery was finally in stock. So I took it out there today, was told it would be a 15 min process. Try an hour, and because of Covid restrictions, I could not wait inside out of the cold, instead standing outside watching the traffic pass by.
Anyway, all of that now has the big cat cranking like a champion. I was sent a PDF of the battery change procedure that Jaguar techs follow when doing this job, not a simple new for old process. That is why I paid for the dealer to do, and endured the clunky customer service. If something go's wrong, it's on them.
Lesson learnt from this, DON'T break a windscreen in a Jaguar XE, it will cost you $3000!![Roll Eyes (Sarcastic)](https://www.jaguarforums.com/forum/images/smilies/rolleyes.gif)
Oh, and the battery was $685!
![Icon Neutral](https://www.jaguarforums.com/forum/images/smilies/icon_neutral.gif)
AZBob (07-19-2021)
An alternative, these Braille batteries will save you 40 Lbs vs our car's oem and large heavy (50lbs) lead battery. Many people may be interested in in a marginal but 24/7 performance and gas mileage improvement. It comes at about $1000.00 though, instead of the Dealer's $685.00 for the lead acid. But...considering the Lithium Ions last 10 years or longer, you'd have to replace at least 2 of the old style batteries in the same period so the long term total battery costs are LESS for the more advanced LI-Ion Braille solution over time, and saves marginal brake wear and engine wear over time. (Makes you faster).
I think it was the I34X, but I called Braille directly to get the exact model. $1049.00 on their site.
They will also offer you a deal on a good trickle charger, I took it. And ask about further discounts on the battery, I got one just for asking.
