XE v6 r sport odd engine noise
Hello. After using the incontrol app to start my car for the first time via that method, I heard a 'clunk' sound 10 seconds after shutting the car off. I would equate it to the sound/loudness of the hood latching. I have not noted this before. Does anyone have any insight? Thanks!
It seems to be 4-5 seconds after shutting the car off. Oddly it started the first time I used the incontrol app to start it. I am unsure if it is the fuel position valve or dreaded sc coupler issue. The sc issue however would make the noise at shutoff, not afterwards, correct? The reason I am nervous is I have only put 500 miles on it since buying it used. My initial impression was it ran great, but imo a little rattle-y at idle. Do you happen to know if the SC coupler clunk sound is present.immediately at shutoff, or if it is delayed as well?
The Jaguar AJ126 engine is not known for its refinement or quiet operation, read the following long-term test of the XE where they complain about the random drivetrain noises:
2017 Jaguar XE 40,000-Mile Long-Term Test (caranddriver.com)
Ryan48 (04-14-2024)
