XE Wheel Dimensions
Does the XE share the same wheel as the XF? Are the offset's the same? If I were to look for 2nd set of wheels from Jaguar, which models would be the same if not XF?
There's not much online for XE specific wheels (for used or like new on EBay, etc...). Figured XF or XJ would be better off. Just want OEM's...
You can check here :-
Jaguar XE 2017 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
and here
Jaguar XF 2017 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
There is a much wider choice for OEM rims in the UK. best view from the UK configurator
UK Configurator
There are a fair few filtering through to UK eBay, some do dispatch worldwide - may be worth considering now that post Brexit the exchange rate for the pound is measured in chewing gum wrappers.
and here
UK Configurator
Lawrence
Alli Quinninho
12-22-2020 03:00 AM
FS[UnitedKingdom]: Set of 4 19" Propeller Alloy Wheels from Jaguar F-Type
PaulParanoia
04-12-2016 05:42 AM
