09 XF 4.2 Luxury overheating.
What engine ? The water pump may not be pumping if some vanes have broken off and fallen inside the coolant jacket. Are you getting heat as usual into the cabin ? Only other thing is a clagged up radiator, either inside the tubes, or leaves and crud off the road blocking the air from passing through.
Timothy
05-16-2012 07:14 PM
