My water pump is leaking on my Jag I have downloaded the service manual for some needed information I have the pump removed but needed service manual to continue
I remove the water pump. And purchased all the new parts and gaskets. I tried to clean up where the antifreeze had leaked onto the valley but I'm not sure if the antifreeze runs clear to the back of the engine or is just contained towards the front I rinsed it out and use my Shop-Vac with a makeshift funnel
I remove the water pump. And purchased all the new parts and gaskets. I tried to clean up where the antifreeze had leaked onto the valley but I'm not sure if the antifreeze runs clear to the back of the engine or is just contained towards the front I rinsed it out and use my Shop-Vac with a makeshift funnel zzz
Conrad.....if you need to order the replacement pipes, suggest you contact jagoutlet.com and ask for Terry. Friendly pricing on new, used Jag parts.
Rock Chalk Bob in Overland Park (E type, XF owner....Heart of America Jag Club).
