2010 XF premium power window issues
The windows need to be reset if the battery is disconnected, becomes discharged, or the power supply is interrupted.
Once the power supply is restored, reset the windows as follows:
- Close the window fully.
- Release the switch. Lift it to the close position and hold for 2 seconds.
- Repeat the lift and release procedure twice more.
- Test the window for correct manual and automatic switch operation. See ELECTRIC WINDOWS.
- Repeat the procedure on each window.
