2011 XF suspension issue
I Need some help???!I have a 2011 XF supercharged and I replace the front forwards control arm and lower control, tie rods inner/ outer and the upper control was replace also. The height sensor on the driver side broke off the nipple in half doing the installation. Now the car shocks rides rough, I check for voltage at the shock connector top and nothing. Do you need to recalibrated the shock system & if so what is the # ???
Did you replace the height detector before you started the engine after the work, or was it afterwards ? If the system detected the height detector was defective then it would have throwna fault code; did you see a fault message on the dash display ? The hard suspension is due to the stored code, so this needs clearing-off first. You might need a recalibration too.
7thward (05-02-2021)
Yes there was a fault code showing when I starter the engine up. That is also when discover the sensor rubber arm was broke in half. Replace sensor and purchase a obdII scanner (Autel MP808) to recalibrate the system. Don’t know if it will work or not? I measure the front wheel center of the rim to the fender and it was 14.5 inches high and the rear was 14.75..
