2012013 jag xf-r low coolant warning light on ( fluid tank is full ) )
i just purchased a 2013 xf-r and it is truly awesome; however, for the last day, i have a low coolant message on; i bought the correct coolant and, after topping it off, and observing it was indeed full, i still have the message; another issue, when the dealer installed two tires from discount auto, they broke the sensor on the left tire and i get the message that there is a tire pressure fault; i took it to discount and they replaced the sensor i had contacted Jaguar about the sensor and i was informed that the sensors used by direct tire use a lower frequency than Jaguar, and thats why their scanner could clear the message; needless to say, i still get the annoying message of tire pressure fault; here in Houston, we're expecting a hurricane either wed or thursday; i will take the big cat to my mechanic ( if we survive the storm )and i will keep all informed pray for us !
Fine, but you're in the wrong forum for your car. This forum is for the XF model from 2015-on. The two models may look almost the same but are totally different mechanically.
For your coolant alarm, you could have a defective sensor if the level looks right in the header tank. The tyre pressure sensor would seem to be the wrong type for the Jaguar system, so you'll always get the alarm based on info from that sensor. However how it all works is beyond me ! Too much tech in modern cars !!
