2015 Brake life
That was certainly typical on the X250 model XF. Heavy cars, and brake pads are relatively soft for smooth braking
Jag dealers typically seem to just replace rotors every time - should have them measure and check tolerances as in practice they should do 2 sets of pads and sometimes three
Note that an indy shop using (better) aftermarket parts is much cheaper than dealer. Last time I did mine (a 2010 XF) it was 1000 for all four wheels incl drilled / slotted rotors and ceramic pads
uab9253 (01-31-2017)
Not to nitpick, but a review of the 2015 XF brakes needs to be in the correct forum for that (X250) and not this one. It may be misleading to those seeking information about the new model. Surprised that the mods haven't moved it.
Received 2,263 Likes
The pads might be worn by 22K miles but the rotors should be good for at least two if not three sets of pads.
A new set of pads is about $50-$100.
You'll find these cars to be very expensive to maintain if you go to a dealership.
It may not be ops fault. The header for this section says XF (X260) with a subtitle of "2015 onwards". Needs to be changed to show 2016 onwards to prevent confusion.
