2016 XF AWD engine coarseness
Only had my new 2016 XF AWD Prestige a week. it seems when I am driving it fairly easily and accelerating through 30 to say 45 mph I feel a coarseness in the steering wheel. If I drive it off the line more aggressively it takes off and I don't feel anything unusual. Is this common with this 340HP Supercharged engine. All seems normal otherwise and it isn't the wheels or driveline, just the engine coarseness under about 45 to 50 and up mph.
I am used to my BMW 528i which which accelerated at any speed smoothly without feeling the buzziness/coarseness. Any ideas?
AL
AL
Thanks for your reply.
AL
The vehicle overall is great. The problem I have with it is when driving off down the road at a slowish pace. The only feeling I should get in my hands is some road feedback which is normal. What I get is extra brrrrr vibration at certain speeds which go away with resolutely pressing the gas pedal. If I drive off like many do sort of aggressively the engine comes alive and really moves! But I live in a quiet community where I usually drive around town at about 30 to 40 mph which means I will get this feedback from maybe the engine which seems to be straining because the 8 spd txn is perhaps in too high a gear. I am going to see the dealer asap. Otherwise what a terrific car. I am going to drive it around a bit using the paddle shifters to try and isolate these coarse feelings from somewhere.
AL
AL
The system is not active until about 30 MPH so that could well explain what it is. No engine problem, just technology trying to run your driving life. I rather like it but it is a pain on some roads. The criteria is that lanes are supposed to be 8 feet wide for it to work and it usually does well even in construction areas where the lanes are narrower. Once in a while though it activates and can scare the devil out of you if you are in tight lanes on a freeway!
Do you have the lane keeping assist (LKA) turned on? There are two settings for the LKA plus off. One is to vibrate the wheel when the system determines you are not between the lines and the other is steering assist which actually nudges the wheel in the direction you should move to remain between the lines.
AL
I have noticed the same thing, except mostly at lower speeds. It's like the transmission is confused. The engine almost feels like the old cars where you think it's going to cut off. I am going for my first annual service in a month or two and I am going to ask the dealer to look at it.
AL
FS[NorthEast]: Set(4) of XK8 17X8 "Revolver" Style Wheels
sg18438
10-06-2016 03:56 PM
FS[NorthWest]: 1998 Jaguar XJR, VIP Style Build, Immaculate - $9450 OBO
xjrjag
10-02-2016 01:29 PM
