2017 interior water leak ponts?
I appear to have an interior water leak on my 2017 XF. Every time it rains the interior windows fog up. Without digging further I can not find any interior water leaks. What are the common points on this car that are known to leak water so I can focus my search there?
Thanks,
Chris
Thanks,
Chris
Update: The rain just stopped. I found water at the rear interior C pillar cover. So, fin antenna on the roof, sunroof drains or the CHMSL. Trunk is dry, carpet is dry. Where do the rear sunroof drains exit? Also, best way to drop the headliner down enough to access the antenna?
Thanks,
Chris
Thanks,
Chris
I've dealt with that issue on my rear passenger door. That was odd to say the least. Opening a door and it sounds like a fish tank. I'm surprised that no water was able to get around the plastic membrane on the door and int the interior when that happened.
I did find this about a leak from the 3rd brake light: https://static.nhtsa.gov/odi/tsbs/20...42401-9999.pdf
Since I need to take the head liner down I'll replace that part. The antenna does appear to be a bit on the lose side, but the gasket appears to be built in and not a separate item.
It's not a physical connection antenna. It's more of a 'collector' that then transmits an increased signal through the roof to an amplifier. There's coils at the base. At least that's the way I've seen it on several of them and I don't see why Jaguar would do it any differently. Anyone know for sure with the Jag?.
Here are a few images of the XF antenna:
https://www.prestigecarpartsuk.com/p...9-fw9319c089db
https://www.ebay.com/itm/365022667462
One was on a MB and the other a BMW. There were no components visible in either one like with the Jag pictures you included, just bare coiled wire under clear silicone. Yes, I would say the XF definitely would have holes in the roof, especially seeing those nuts and bolts! Mine were knocked off by a garage door closing prematurely and the other by some vandals. I assumed all were all like that. Learn something new every day. Find the source of water ingress?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
