2017 xf leaking under water pump
Hey gents,
I'm stuck when it comes to my 2017 XF. I recently had a coolant leak that i discovered was coming from my pump. After replacing my old pump with the new one, now im getting a constant flow coming from underneath the new pump under the left bottom side of the pump. I have cleaned and reseated the pump 100 times and for the love of God I can not figure out why is it still leaking. I have even made sure the gasket are contacting correctly. Need some help
thank you
thank you
