on 2017 XF S: exactly where are the doors' drain holes?
Received 13,103 Likes
Hi iraklio,
Welcome to the Jaguar Forums! It's great to have you with us.
I deleted your duplicate thread - please do not start multiple threads on the same topic.
Also, I moved your thread from the forum for the X350 to the forum for the X260, which is the Jaguar factory project code for your 2017 XF-S. Here you will find knowledgeable members of similar cars.
In the meantime, please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Cheers,
Don
I had clogged drain holes from the factory build in right rear door as I was getting a sloshing sound when stopping or reversing and stopping. Dealer cleaned out holes and no further problem. Not uncommon on many cars btw
Don B (05-29-2018)
More common on our cars though. There's a thread on improper door seal hole to door drain hole alignment. Try just pulling the seal away from the door at the rear lower corner and watch the water flow out. The seal isn't attached with adhesive all around, just at spots with through-the-door push fasteners, and it's easy to do. In your neck of the woods I would be doing it often
![Icon Biggrin](https://www.jaguarforums.com/forum/images/smilies/icon_biggrin.gif)
Mile_Hi_Kat
05-03-2018 12:30 PM
FS[NorthEast]: 2017 Jaguar F-type Coupe 6-speed Manual
chowderjag
04-11-2018 02:35 PM
