'21 XF Exhaust Tips
'21 XF Exhaust Tips
Has anyone found any aftermarket exhaust tips for the '21 XF? There's an opening in the skirt for dual pipes, but the exhaust terminates with a single pipe that bends down before it even gets to the opening. The pipe is at the inside edge of the arch opening on the bumper, so finding a set of tips that will offset and line up properly has been impossible so far. Anyone have an answer? It looks like almost everything from prior years has exhaust tips as standard. How could they delete something so basic on a performance car?
Where are the exhaust tips on the MY21 XF?!?
Tips appear to be STANDARD on all XF before MY21!
If you do not want a trip to a custom shop the only thing you could do is to put a non-functional exhaust tips, like. they are there for cosmetic purposes only. As you mentioned on your original post, the current exhaust pipes are pointing downwards and If you want that to be functional the pipes need to be straighten out in order for them to be welded or bolted on into the aftermarket exhaust tips.
