B12bd-18 camera fault code
Does anyone know what tests I can do either voltage tests or resistance tests to check if the camera is faulty
it’s not the wiring in the boot I have a fault code check list but it dosnt state what voltages and resistance I should get
it’s a ictp with s single module
it’s says I should test with a meter capable or 2v and 2k ohms bits that’s all I know
