Battery problem
Battery problem
Hello, I didn't find any information about it, so I'm starting , so I have a problem with my multimedia it doesn't work , when I get the negative cable out and input it back the multimedia shows the jaguar logo and after turn off, so just when I get the cable out and input back it happens, my question is, my battery needs to be 100% to work ?because I already tested the modules and connections everything works well, I tested my battery in 3 different stores ,two said the battery is good but the state of charge is 60% and the CCA is 613. and 1 said the battery is bad. I don't know if I buy a new one or look for problems on the multimedia.
No, the battery doesn't need to be 100% for the multimedia to work. It could be a software update or another compatibility issue? What doesn't work?
OK thank you so much The multimedia doesn't work at all, it just shows the jaguar logo if I take the battery cable out and input it back, if I don't do that it doesn't show anything
snkpkp
01-14-2021 09:52 AM
BigCat09
12-04-2019 03:06 PM
cat_as_trophy
01-26-2014 07:40 PM
Mark Scotton
24
01-23-2013 09:27 PM
Mccalist
12-14-2009 09:05 AM
