Blind spot X260 wiring
Has anyone got a wiring diagram for the X260 blind spot I have sourced the parts and a complete rear bumper loom and found a diagram online for the f type which is 8 pin but the wiring isn’t right for this as pin 4 is for warning alert on my diagram and is capped off and pin 3 for status and ignition is spliced together
I know it’s different and uses can
my door looms are already prewired just don’t know where to connect the wires from the modules any help would be brilliant mate have attached a pic
Unfortunately not. But you don't have to worry about your door looms as you already have the complete BSM/BSA wing mirror assemblies. You only have to alter wiring if you didn't and were only adding the actual BSM/BSA mirrors.
For the radars you might be lucky and already be pre-wired for that. But probably not. In which case you'll have to tap CAN, live & earth from the closest source.
left module
pin1 and 2 private can network between each other
pin 3 and 8 live
pin 5 negative
pins 6 and 7 can network
Right the same apart from pin 3 is a negative instead of a live does this sound right
just unsure about the can networks
as I have a blue and green pair and a purple and green pair
One thing I still Carnt find is the as built file for the sodl and sodr I have no zip file on my pc with all as built files from my year looked everywhere
once complete I will put a post up about how to do it and what’s needed on the X260 as there isn’t much around about how to do it and I seen a few posts of people asking
Supermans1 (01-26-2022)
I would start with the thread Toxo wrote about the retrofit on the X250. It will give you a better understanding and it's very informative. Then you can work on adapting it for the X260
https://www.jaguarforums.com/forum/x...trofit-232724/
