XF (X260) 2015 onwards
blowing fans with no heat
Old 11-15-2018, 04:14 PM
blunt's Avatar
Default blowing fans with no heat
I have a 2009 jaguar xf,....the problem is the engine fan blows constantly I've seen the over heating message several times but then it goes away....inside blower works but there is no hot air through vents....
Old 11-16-2018, 09:23 AM
ololly's Avatar
I would suggest posting in the correct forum for X250 model, but give my 2 cents nevertheless (disclaimer: don't trust blindly to a suggestion of a random dude on the internet)
1. If you are loosing coolant you have a crack at a heater core.
2. If you are not loosing coolant then your heater core is clogged.
Either way let your mechanic to check the heater core. I doubt you can do it yourself, but there is no need to go to a dealer for 2009 car either. Find a reputable mechanic and buy a part from a junk yard.
Old 11-16-2018, 09:29 AM
blunt's Avatar
somebody also mentioned it may be the thermostat...but I will definitely have them look at the heater core they want 680.00 to replace thermostat seems pretty expensive for that fix...
Old 11-16-2018, 09:33 AM
ololly's Avatar
Well, the part itself (the thermostat) costs around $100 and I believe you can actually replace it yourself (again, for the right suggestion post in the forum for your model year). And for the car that old there is no need to go to a dealership with their $200 hourly rates.
Find a good mechanic and stick with him/her. This is not a major repair.
Old 11-16-2018, 10:02 AM
blunt's Avatar
thank you sir I appreciate the knowledge you shared with me....
Old 11-17-2018, 06:56 PM
BritCars's Avatar
You need to urgently find someone who knows what they are doing and investigate the problem. These engines will warp if overheated and are next to impossible to rebuild. It will set you back $10k plus to replace - ie car is written off. Read around the forum - it has happened to several people
If it's telling you it's overheating you need to diagnose fast before you drive it more
Do you have a good independent shop who knows these cars? Or a code reader and post all the codes up here
Old 11-20-2018, 12:48 PM
blunt's Avatar
Default pricing
I was told I needed a water pump and thermostat housing unit and was quoted 1350.00 is that a good price..
Old 11-20-2018, 01:43 PM
ololly's Avatar
I would strongly advise to ask at the right forum. Our (X260) cars are still under warranty, so I can't imagine somebody will advise you on the price here. Go on X250 forum and ask there.
ragman1171
02-18-2016 10:37 AM
kulddy
08-15-2015 05:12 PM
rjaguar
06-01-2014 12:40 PM
FreakingAwesomeJag
03-07-2014 11:56 AM
Bacardi 151
24
05-29-2012 05:03 PM
Quick Reply: blowing fans with no heat
