Central Locking
Hi all
I have a 2016 XF which is having problems with the central locking, this started happening last winter and stopped over the summer but is back now. Basically, the central locking will not work when you try it initially. If you press the button loads of times it will eventually work and when the car warms up it works, I think it is a problem with cold and damp weather. It is not a problem with the key as the problem happens with both keys even when they are stored in the house. The problem also started again as soon as the weather became much more damp a couple of weeks ago and is becoming a real pain.
Has anybody see this before?
Thanks in advance
Liam
Thanks in advance
Liam
