XF (X260) 2015 onwards
Charging System Fault
Old 10-29-2018, 12:14 PM
mleskovar's Avatar
Originally Posted by EKinSC
Thanks that is a good suggestion. When you say take a reading off the jumper terminals. I know where the positive terminal under the hood is. When the tow driver jumped it he put the negative on ground. Is there a negative terminal under the hood as well? I don't recall seeing one.
EKinSC
On the passenger side shock tower there's what looks like an extra long bolt/thread (it's not really a thread) sticking out an inch but any ground will work.
Old 10-31-2018, 11:54 AM
Received 2,192 Likes on 1,358 Posts
Originally Posted by ekinsc
ok so i got home friday and didn’t drive the car until tonight. The charging system fault warning and battery light came on again. Back to the dealership tomorrow. Hopefully i’ll make it and not have to be towed in again.
Ekinsc
look, with the charging system fault light on that meens the alternaotr is not charging and so youre running only on battery power. And with todays heavy electronic cars you will never make it far and would never recommended to drive it. I would say your alt is going out and it is common if theres a oil leak from either the cam cover, front cam timing chain cover on passenger side or oil filter housing. All of which are right above the alternator and drip into it causing it to eventually fail. I have never seen the charge warning come on for a battery and was surpised they just replaced that and not the a;ternator too. It seems intermittent right now which can be a diag problem however i and others know this is a issue when there are leaks into the alt. On the v6 and v8's
Old 10-31-2018, 12:00 PM
EKinSC's Avatar
I spoke to the service advisor today and they replaced the alternator. He said everything else checked out. A technician took the car home last night and the check engine light came on but not the charge light. They are sorting that issue now and they are going to drive it a couple more days to ensure it's fixed before they give it back to me. I am guardedly optimistic.
EKinSC
Old 10-31-2018, 12:49 PM
mleskovar's Avatar
Originally Posted by Brutal
look, with the charging system fault light on that meens the alternaotr is not charging .....
As far as I know there's no separate light for battery and alternator. With the sophisticated electrical systems in cars today you can have the light come on, have some electrical appliances in the car shut off automatically, and continue on until the battery reaches charge status from the alternator or you replace it. And alternators are probably one of the easiest components to check..... 14.5V with engine running then it's OK.
Old 11-02-2018, 06:58 PM
EKinSC's Avatar
Got a call today the car was ready to pick up. They replaced the alternator to fix the charge system fault issue. The invoice noted "Once battery was recharged performed charge system test with SDD. Found generator to have failed. Replaced and performed long drive cycles as well as letting vehicle sit. Rechecked battery. Test passed. Charge system working as intended at this time". The check engine light issue was also fixed. Note says "Faults B1D14-11 and P065B-16 active. Found internal failure in overhead console for lights and roof opening panel not working. Replaced console.". The roof was working before so that must've just went out or something. No charge as all work was performed under warranty. Drove the car 25 miles home and everything worked perfectly. I'm going to drive it around this weekend just to make sure but I think the worst has passed.
EKinSC
Old 11-02-2018, 07:50 PM
mleskovar's Avatar
EKinSC
I may be too cynical but I don't buy their story. If the alternator was bad the SDD would have picked it up the first time and you don't replace a two year old battery without checking the alternator. I wonder if the 'console' was the culprit? Anyway, I would definitely monitor the battery with a DVM just for peace of mind.
Old 11-02-2018, 08:34 PM
EKinSC's Avatar
I did take your advice from earlier and ordered a DVM off Amazon. It arrived this week. I’ll be keeping a log of voltages at various times for a couple weeks to make sure. Thank you for the directions on how to do this and what to look for. I’m not much of a mechanical type.
https://i.postimg.cc/j5Vbvx0B/858-AF...-C1-D200-E.jpg
EKinSC
  #28
Old 11-02-2018, 09:31 PM
mleskovar's Avatar
..... I’m not much of a mechanical type......
Most people aren't and that's why auto repairs are so expensive .... because they can. Remember to take voltage measurements at least 1/2 hour after anything that uses electricity so the battery can have time to rebound. Opening doors, touching door handle, lock/unlock, open trunk, radio, etc. It's a good idea to release the hood latch when you get home at night and take a measurement 1/2 hour later. Then don't close hood and take one in the morning before starting off. Red lead to + battery jump terminal under two plastic covers and black lead to any ground (like bolt to body, not on paint though). I'm curious what you measure.
Old 10-16-2021, 10:38 AM
Steve L 1079's Avatar
Default Intermittent charging system failure
Hi all 1st time posting in a forum but hope this helps anyone with this issue, I have had this intermittent fault for a couple of weeks now, the warning light displays but only stays on the dash board for a few seconds then clears, after a trip to my local jaguar dealer they were unable to locate the fault. Annoyed the fault was still happening I called a jaguar specialist and spoke to an engineer who stated this was a common fault, he suggested checking a small cable on the positive battery connection. ( battery monitor cable ) I found this was really loose, I have placed a washer under the bolt and tightened with socket set and its been fine ever since.
Jaguar4Me
09-02-2021 03:18 PM
lrizzell
11-04-2019 11:01 PM
PBBarb
04-19-2019 08:09 AM
jcboulos
01-28-2013 05:25 PM
Quick Reply: Charging System Fault
