Configurable Dynamics Steering &
What does Configurable Dynamics Steering change? Resistance/stiffness at speed? I'm also still trying to figure out the differences between S mode and Dynamic mode. Am I missing something or is there redundancy between them? I see where the gear is displayed in S but other than that what's the difference? Does anyone switch between the options much?
Yup. S changes transmission behavior and is independent of the other settings. Also, depending on your settings, S may also enable the paddles.
Dynamic mode, assuming you have everything configured to dynamic, affects steering, gas pedal response, and suspension response (if you have the dynamic suspension).
